Activity Forums Adobe Photoshop how can I get this effect?…
  • Jacki Schklar
    April 19, 2007 at 2:06 am
    Those are original artwork, not from photos.
    But experiment with art filters. It does not take long to click on a filter and look at the results or check out the filter gallery.
    -Filter
    -Filter gallery
    You might like this:
    -Image
    -Adjustments
    -Threshold
  • Joseph W. bourke
    April 20, 2007 at 7:26 pm
    At least two of those images are woodcuts or linoleum cuts, made by cutting the inverse image into a block of wood or linoleum, then using the block as a printing plate.
    One way you might go is to make your image black and white, then use the brightness and contrast filters to simplify your grey levels, then make a selection from the black or white that’s left and paint using that selection. You might want to do a couple of passes using variations on the brightness and contrast. This could also work separating the color channels and working that way. Experiment!!
    If I remember correctly, there was an Adobe Gallery Effects filter called woodcut that may still be in Photoshop.
    Joe Bourke
    Art Director / WMUR-TV
