Activity › Forums › Adobe After Effects › How can I get motion Blur when using card cance?
  • How can I get motion Blur when using card cance?
    Posted by Mano Lis on November 21, 2007 at 11:37 am
    Hi Guys,
    Do you know if it’s possible to get
    motion blur with card dance? I rendered
    a scene with motion blur on, but there was no
    blur in the final video. Any ideas?
    thanks,
    manolis
    Mano Lis replied 18 years, 10 months ago 2 Members · 6 Replies
  • Steve Roberts
    November 21, 2007 at 12:59 pm
    Motion Blur only works with layers that are changing position/rotation/scale, or effects that specifically have MB as part of their controls.
    You could precomp the Card Dance layer, then apply CC Force Motion Blur to it. If you’re using the comp camera, you probably need to include that in the precomp.
    Or you could apply CC Force Motion Blur to an adjustment layer over the whole thing, probably.
  • Mano Lis
    November 21, 2007 at 6:25 pm
    Hi Steve,
    Thanks for the response!
    I’m using an original version of AE CS3
    and there is no “CC Force Motion Blur”
    Where can I found it?
    Manolis
  • Steve Roberts
    November 21, 2007 at 6:46 pm
    Under the “effects>time” menu?
    (if you hit F5, you can enter the name of the desired effect into the window to find it)
  • Mano Lis
    November 26, 2007 at 10:14 pm
    I’m sorry, but I can’t find
    “CC Force Motion Blur” anywhere.
    I’m attaching an image from my AE CS3 effects
    drop down.
    Thanks a lot,
    manolis
  • Steve Roberts
    November 26, 2007 at 10:41 pm
    Ah. Thanks for the screengrab.
    Did you install the Cycore effects from the AE install CD?
    (if you have an educational version, that may not be an option)
  • Mano Lis
    November 26, 2007 at 11:30 pm
    I found out why the effects (cc force motion blur,…)
    weren’t showing up!
    I checked the after effects plug-ins folder
    and I noticed that there is a cyclore folder,
    so what I did was to copy and paste all
    cyclore plug-ins from the subfolder into the parent plug-in folder.
    I restarted After effects and woila! the effects were there!!
    Don’t really understand why it can’t see the plug-ins in
    the subfolders but happy to have found a solution.
    Manolis
