Activity › Forums › Apple Final Cut Pro Legacy › how can I get a 25fps progressive timeline??
  • how can I get a 25fps progressive timeline??
    Posted by Liammorgan on October 14, 2006 at 12:38 pm
    I’m shooting a music video in 25p format (from a PAL XL-2). Usually I conform my footage to 24fps to edit, so as to keep it progressive. But as this project is a music video, conforming the footage will put it out of sync with the song. Anyone know a way to create a 25fps progressive timeline? Cheers.
    Liam
    Jeremy Garchow replied 19 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    October 14, 2006 at 6:41 pm
    Digitize as your normally would (50i) and then open your timeline settings and change the field settings to none.
    Jeremy
  • Liammorgan
    October 15, 2006 at 1:26 pm
    that simple, eh? thanks
  • Jeremy Garchow
    October 15, 2006 at 4:38 pm
    Yes it’s that simple. The signal still gets recorded to tape as a 50i stream, the difference is that both of the fields on one frame are exactly the same. You then change your field dominance settings in the timeline and that way FCP won’t reintroduce interlacing when rendering. Cool huh?
    Jeremy
