Activity › Forums › Adobe After Effects › How can I fix this?
How can I fix this?
Posted by Ns-5 Sonny on November 9, 2007 at 12:38 pmHi guys.
I hope you can help me to solve this.
I edit a sequence in my Adobe Premiere 2.0 and export it as an .avi file. If I play the .avi, its ok, but if I open it in my Adobe After Effects 7.0, it looks terrrible, take a look https://img249.imageshack.us/img249/3607/lossofqualityqv6.jpgPlease, if you know how to solve this, helpe me.
Ns-5 Sonny replied 18 years, 9 months ago 5 Members · 8 Replies -
Steve Roberts
November 9, 2007 at 1:22 pmOr maybe the video is progressive, and AE has interpreted it as interlaced. Select the footage in the project window, then “file>interpret footage>main”, and “separate fields>off”.
Kevin Camp
November 9, 2007 at 3:50 pmif these suggestions don’t help, can you tell us more about you original footage, and any settings that you used when exporting the avi…?
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Darby Edelen
November 9, 2007 at 4:31 pm[Steve Roberts] “Or maybe the video is progressive, and AE has interpreted it as interlaced. Select the footage in the project window, then “file>interpret footage>main”, and “separate fields>off”.”
I made that suggestion in response to the same question (same footage) in a different thread about a week ago… I assumed the problem went away as there were no follow up questions from the poster.
Please don’t give up on your threads! Tell us what works/doesn’t work so we can sleep at night…
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Kevin Camp
November 9, 2007 at 4:45 pm[Darby Edelen] “Please don’t give up on your threads! Tell us what works/doesn’t work so we can sleep at night…”
not only that, but if someone else has a similar problem and they read your thread, it would be nice if they knew what help.
Kevin Camp
Ns-5 Sonny
November 9, 2007 at 5:46 pmThanks for all the answers guys.
Steve Roberts, The “file>interpret footage>main”, and “separate fields>off“. was the perfect solution.
Now I’m happy. UP 😉
THANKS a lot
