Activity Forums Adobe After Effects How can I fix this error: AEGP Plugin CINEWARE SceneLayer: CINERENDER – Connection failure (5027 :: 12)
  • How can I fix this error: AEGP Plugin CINEWARE SceneLayer: CINERENDER – Connection failure (5027 :: 12)
    Posted by Amaury Diaz on December 30, 2014 at 4:15 am
    Helllo I’m new working with AE an cinema 4D, I get the error “AEGP Plugin CINEWARE SceneLayer: CINERENDER – Connection failure (5027 :: 12)” when I launch AE, and I think it does this for every .c4d file I have in this project. I can see the file just fine in C4D lite, and in after effects I see a black screen in the comp window. However I can see the thumbnail of the c4d file in the project window when I have the c4d file selected. The layer is active in the comp’s timeline as well. Not sure what to do about this. Any ideas? Thanks for the help.
    Amaury Diaz
    Don Daedalus replied 8 years, 6 months ago 7 Members · 7 Replies
  • 7 Replies
  • Rob Smith
    January 15, 2015 at 9:23 pm
    Try this:
    Go to the Effects Control panel and click on Cineware Options
    Under CINEWARE TCP PORT mine was set to 5030 and I changed it to 5027, and now I can see my CD4 layer in AE
    Hope that helps!
  • John-henry Keenan
    April 14, 2015 at 7:39 pm
    Changing the TCP port to 2027 worked for me too, but I also had to purge my memory and disk cache (Edit – Purge – All memory and disk cache), then quit and reopen after effects for the changes to take effect.
  • Mike Horn
    November 13, 2016 at 2:58 pm
    I was able to fix it by running After Effects as Admin (on Windows 10). My port is still 5030. I also added the Cinema 4DAE.exe plugin and Cinema 4DLite.exe apps to my Windows Firewall approved apps list, although I’m not sure if this would have made a difference.
  • John Younger
    September 8, 2017 at 10:03 pm
    Just FYI when you get too many C4ds in your AE project it can cause this error. Removing some helped.
  • Don Daedalus
    January 10, 2018 at 9:22 pm
    This worked for me also (2017 MacBook Pro, High Sierra + Adobe CC 2018 +C4D R19).
    While After Effects wanted to send me to change Communication–>Live Link in C4D, that didn’t fix the problem.
    I got the error until I changed the Options in the Cineware Effect in AE. I changed the port number to 5020.
    A previous, similar error pertained to the permissions that plague OSX High Sierra: for that, I found Apple’s own explanation was best.
    The permissions just on the Maxon folder in the Applications folder can be changed (Get Info, unlock, change permissions for user to Read & Write, click gear to Apply to enclosed items…) worked also.
    -D
  • Luis Marin
    February 21, 2018 at 4:17 am
    Same problem here.
    Pls someone help!!!
    I’ve read and applied all your fixes, still not working.
    – TCP Port change
    – Purging cache
    – Changing Maxon Permissions
    Do you reccomend upgrading to CC2018 / c4d19???
    Macbook Pro Retina 2016 / 16gb RAM / Adobe CC2017 / C4d18 /
  • Don Daedalus
    March 13, 2018 at 7:18 pm
    I spoke too soon. I still have the issue.
    Upgrading to High Sierra or AE 2018 has not solved the issue.
    -DHPD
