Activity Forums Adobe After Effects Expressions How can I figure out the legnth of a path.
  • How can I figure out the legnth of a path.
    Posted by Chris Scalzo on March 16, 2015 at 4:36 pm
    The problem I’m having is I’m animating a stroke on with trim paths (which is measured in percentage of completion), and have a text layer writing it on with the path options. The First margin property is measured by length of the path. I plugged in a slider temporarily to adjust this value to re synchronize them after moving the path around. I would much prefer to somehow read the length of the path with another expression so it stays lined up as I adjust the path.
    Charlie Leroy replied 11 years, 5 months ago 3 Members · 3 Replies
  • Dan Ebberts
    March 16, 2015 at 5:44 pm
    I’m not sure if this helps, but it’s the only thing I can think of. If you copy the path and paste it into the position property of a null, the null will trace out the path at a constant speed over a two second period. So if you have a slider controlling the percentage, you can convert that to pixels traveled with something like this:
    pct = effect(“Slider Control”)(“Slider”)/100;
    thisComp.layer(“Null 1”).position.speedAtTime(0)*2*pct;
    Dan
  • Chris Scalzo
    March 16, 2015 at 6:29 pm
    Thank you for the quick response. I spend around two hours searching for a quick solution. What I have now would probably be easier to manipulate for my current needs. I saw a response you made on paths to someone else stating there is little you can read with expressions on a path. I am running 2014.1.1 and was hoping this would have been updated in 2014.1.2 like the text bounds thing. Anyway, thanks again. I have much respect for your content on creativecow. 🙂
  • Charlie Leroy
    March 17, 2015 at 3:50 pm
    Hello Chris,
    If I understood correctly you have your stroke going from 0% to 100% and the text layer is following the “moving tip” of the stroke. is that correct?
    if it is, then you can do this;
    you know the First margin starts and the first margin finish
    this should make your text starts and finish at the same time as the stroke appears ( if both the path and the stroke are the same obviously)
    on the First margin value
    //initial margin value
    var x=1641;
    //final margin value
    var y= 3086;
    //the End trim percentage
    var z= thisComp.layer("Shape Layer 1").content("Trim Paths 1").end;
    //cross product
    value =z*(y-x)/100+x
    hope it helps.
