Activity › Forums › Maxon Cinema 4D › how can I extrude a square face from a rectangular plane?
  • how can I extrude a square face from a rectangular plane?
    Posted by Joe chapman on September 20, 2021 at 11:34 am
    I want to recreate this image- a rectangular table top with square legs. Is there way that I can extrude a square face from four corners of a rectangle so that the legs and table top look seamless?
    Jim Scott replied 5 years ago 2 Members · 1 Reply
  • Jim Scott
    September 20, 2021 at 2:44 pm
    Set up the dimensions and segments of the base cube so that its polygons will be squares when it’s made editable and you’ll be able to select a square of polygons to extrude. In your case, the Y segments aren’t important, but for my example I made them all proportional.
