Activity › Forums › Apple Final Cut Pro Legacy › How can I export my Timeline in to seperate Clips?
  • How can I export my Timeline in to seperate Clips?
    Posted by Franz Krekeler on April 3, 2010 at 8:06 pm
    Hi everybody,
    I’m enjoying CreativeCOW more and more recently.
    And there’s something I need to be more creative ^^
    How can I export every Clip in my Timeline seperately?
    For Example I have cutted 2 Clips and I want to export them into:
    Clip 1 Part 1.mov, Clip 1 Part 2, Clip 2 Part 1, Clip 2 Part 2 and so on.
    Is it possible?
    Sincerly,
    Franz Krekeler
    Nick Meyers replied 16 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    April 3, 2010 at 8:36 pm
    You could get there by using media manager on the sequence. It would create a new sequence and set of clips that are only what are in that sequence. Click the options “delete unused media” and choose copy, and create a new project file.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Franz Krekeler
    April 3, 2010 at 8:40 pm
    Thank you for your quick reply.
    Well I tried Media Manager but strangely enough it does not work.
    Any other suggestions? Cant be so hard.
  • Michael Sacci
    April 3, 2010 at 8:49 pm
    You can use Media manager of the sequence
    Media settings
    Copy
    UNSELECTED – Include master clips outside selection
    SELECTED – Delete unused media from duplicated items
    (set handles if you want them)
    The naming of the clips are tied to the actual clip name or what you rename the clip within FCP bins.
    Project
    Selected, and it will put all the clips in a media folder.
    – Our software is idiot-proof, if you bought it it proves you are an idiot. – Dilbert
  • Chris Tompkins
    April 3, 2010 at 10:29 pm
    I just user in and out marks on the time line to output sections or clips.
    Chris Tompkins
    Video Atlanta
  • Michael Sacci
    April 3, 2010 at 10:36 pm
    what do you mean by it doesn’t work. One thing there is no destination set in that screen capture.
  • Robb Harriss
    April 4, 2010 at 12:21 am
    Now that was a really clever answer.
    Non-linear: all the time and nothing but.
  • Nick Meyers
    April 5, 2010 at 2:48 am
    the Media Manager WONT work if all your clips are contiguous.
    that is, if you have simply BLADED a longer clip in the timeline,
    and each frame naturally follows the previous one.
    this can also happen if you have been working form the viewer and your new in point is the next frame on from your last out point.
    MM will do the most EFFICIENT export, joining clips back together into one file.
    one approach is to select every second clip,and raise them to a new track.
    Media Manage the two tracks seperately
    another way to get around MM is to remove TWO frames from every edit.
    ONE frame only doesn’t seem to work, as M will always ADD a frame to your selection.
    so if you remove TWO frames from your timeline, you’ll really only lose on as you get one back.
    weird!
    but if you need eery frame, then this is not for you.
    another way is to copy all your timeline clips into a new bin,
    then BATCH EXPORT.
    if your clips are all the same name batch export will not like that.
    you would have to rename them manually.
    but best to select all the timeline clips, right click and “make independent clip” first.
    nick
