Activity Forums Apple Final Cut Pro Legacy How can I Export AVCHD files for vimeo as fast as possible?
  • How can I Export AVCHD files for vimeo as fast as possible?
    Posted by Ciarán Maher on April 28, 2011 at 6:06 pm
    Hi all,
    Recently a client asked if i could import a ton of clips from his shiny new camcorder. He wants a simple Title added at the start of each clip (no problems with this) and then have the clips exported into files ready for his website, I usually use the settings vimeo recommend for DV and they are fine in terms of quality for him. No problem i said, so I took the camcorder home. I captured the AVCHD (MTS Files) footage using Log and transfer and I knew in advance this would take a little time. I used Pro Res 422 codec. So I took the first of the new MOV files onto the timeline, its about 8mins 50secs long. I added the title at the start – 6 secs extra.
    Now the trouble starts…
    Using export settings for Quicktime – H264, FCP 7 is taking an hour to export roughly 10 mins of unedited footage (excluding the title i know).
    I dont want to walk from the job because of the time it will take (about 20-30 clips, most around 10 mins but some as long as 30 so it could be over 50 hours of exporting)
    The machine I have isn’t the fastest but i really thought it would do better than those speeds.
    MacBook Pro 13, April 2010 model, OSX 10.6.7, 2.4Ghz Core2Duo, 4GB RAM
    Any help or advice for me to speed up what should be an easy and speedy process would be greatly obliged!
    Ciarán Maher replied 15 years, 4 months ago 4 Members · 4 Replies
