Activity › Forums › Apple Final Cut Pro › how can i export Audio only final cut X?
  • Bill Davis
    April 26, 2012 at 7:02 pm
    Share Menu.
    Export Media.
    Select Audio Only.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • King Law
    April 26, 2012 at 8:08 pm
    lol!! i feel so stupid thanks man!! managed to export it to Adobe audition and fixed it thanks man im still trying to figure out this final cut X thing!
  • Richard Herd
    April 26, 2012 at 8:57 pm
    Audio in FCPX…the Jim Giberti Technique. I highly suggest it.
    In a nutshell, you start your picture with a gap clip. Then attach a secondary piece of audio to that gap clip. THen turn the secondary into a primary.
    “P” is your friend here because it allows you to put audio in the primary wherever you want it by placing it and then sliding it where you want. You can assign a role to it and export accordingly.
    In X there are effects from Logic built in and they sound great. You can then create compound clips and apply effects to the whole CC (a kind-of bussing).
  • Jim Giberti
    April 26, 2012 at 9:37 pm
    [Richard Herd] “”P” is your friend here because it allows you to put audio in the primary wherever you want it by placing it and then sliding it where you want. You can assign a role to it and export accordingly.”
    “P” really doesn’t get the respect it deserves does it?
    Also “,” and “.” these are the things that make a hybrid approach possible in X.
    We should start a thread of the little things (P certainly is a big thing) that make editing fast and that are demonstrably different from legacy and other NLEs. They can get overlooked because of that.
    Like, in audio editing, Control/+ Control/- for making fast 1DB adjustments to clips.
  • Richard Herd
    April 26, 2012 at 10:13 pm
    [Jim Giberti] “We should start a thread of the little things”
    CTRL-S it splits audio from video to make J cuts and L cuts incredibly efficient.
  • Richard Herd
    CMD-8 for bringing up the audio enhancements tab. I use it all the time.
  • Bret Williams
    April 27, 2012 at 6:33 am
    I still find split edits incredibly inefficient. First, you have to press ctrl+s vs. a simple modifier key in 7, option. Once it’s split, doing a roll of the audio portion requires yet another special key I only found mentioned in the manual – shift+. (You have to also position your the cursor first on the right edit.) Without that keystroke you’re only allowed to roll the audio on either side, pushing the other audio out of the way. Even pressing T first only allows the video to be rolled.
    Then, unless you like wasted screen estate, you close up the split to get back that quarter inch gap that does nothing.
  • Kevin Patrick
    April 27, 2012 at 12:31 pm
    Jim,
    Have you ever put all your FCPX audio workflow methods together in one post?
    Kevin
  • Richard Herd
    April 30, 2012 at 12:38 am
    [Bret Williams] ” I only found mentioned in the manual – shift+.”
    I’m not following you here. I don’t have to do that.
    CTRL-S. Then yes I use the mouse in the timeline. And take advantage of the magnetism.
    I also set the editing preferences to show detailed feedback. Then I double click the edits and can precision edit the clips…using the mouse. The results for me have been awesome and much faster than 7 (6, 5, 4, and 3 also).
  • Colin Ryan
    April 12, 2013 at 2:16 pm
    The Share Menu is gone in 10.0.7
    I want to export some bad audio from a clip to fix in Izotope RX. Then i need to chop it up in logic. I just need to export a wav or aif.
    I am looking in File menu / Share/ and there are no options for just audio. Even Add destination doesnt have an export audio option.
    Izotope RX works as a standalone.
    let your fingers do the walking
