Activity Forums Apple Final Cut Pro Legacy How can I edit H264 quicktimes?
  • How can I edit H264 quicktimes?
    Posted by Alex Bluffield on January 12, 2010 at 11:02 am
    Hi – at present my online showreel consists of many 3-4minute clips which are 640×360 H264 movs. I want to edit these into a short highlights reel, but not sure how best to do this. Quite a few of the clips I don’t have access to source material anyone, just the movs. I’ve also encoded flash versions, but don’t really know my way around Flash to edit in that. Any suggestions, much appreciated.
    Best,
    Alex.
    Alex Bluffield
    Final Cut Pro Editor
    W: https://www.a2bpostproduction.co.uk
    Rafael Amador replied 16 years, 7 months ago 5 Members · 5 Replies
  • Ben Holmes
    January 12, 2010 at 12:25 pm
    A quick search for H264 will bring up a lot of recent threads – what with the rise of VDSLRs recently. Try a search for 7D as well…
    Batch convert to ProRes is the usual short answer.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Josh Aderhold
    January 13, 2010 at 9:45 pm
    You can use a program like Mpeg Streamclip and convert it into a quicktime file with a different codec.
    MacBook Pro
    Intel Core 2 Duo
    2.6GHz
    L2 Cache: 6MB
    4GB Memory
    Bus Speed 800MHz
  • Naiche Lujan
    January 13, 2010 at 10:14 pm
    Even Quicktime can convert the files. Try using ProRes to maintain quality.
    Naiche
    Mac Pro
    Dual 2.8Ghz Quad-Core
    16GB RAM
    ATI Radeon 256MB
    320GB 7200rpm
    3TB 7200rpm Internal Software RAID0
    Blackmagic Studio Card (working good so far)
  • Alex Bluffield
    January 14, 2010 at 10:10 am
    I actually need to edit my clips together into one showreel clip. The only way I know to do that is in a timeline… I can trim the individual clips in Quicktime 7, but then how to join them up – hmmm.
    Alex Bluffield
  • Rafael Amador
    January 14, 2010 at 2:22 pm
    Alex,
    A basic edit can be done in QT and without any transcoding or even rendering. Just copy and paste the chops you want in a new window and “Save as” or “Export”.
    If you want something more elaborated, as have been told here, transcode and work in FC.
    Rafael
    http://www.nagavideo.com
