Activity Forums Media 100 How can I easily convert 44100 Hz Audio to 48000 Hz?
  • How can I easily convert 44100 Hz Audio to 48000 Hz?
    Posted by Jerome Robbins on September 19, 2006 at 7:08 pm
    Media 100i XR 8.2.3 G-4 Dual 144
    I have always been using 44100 Hz as my input setting. I understand it is preferrable to use 48000 Hz for use in DVD StudioPro so I am now using the 48000 Hz input for audio.
    The problem is I have a lot of music files that I access and use on my projects that are in 44100 Hz format. I just tried to open a music folder and drag a selection to my new program that is 48000 Hz and I got the message that I can’t mix types in the same program.
    My question is: is there an easy way to convert my 44100 music to 48000? I want to avoid re-importing everything I already have in files that is 44100 Hz.
    Do I open my folders, choose a file, export it, and then re-import it with my hardware import settings set to 48000 Hz for the conversion?
    Thanks for any help,
    jerome
    Kieran Matthew replied 19 years, 12 months ago 3 Members · 2 Replies
  • Greg Ball
    September 19, 2006 at 7:20 pm
    Why not burn your music files to CD then import the tracks from CD into your new program?
  • Kieran Matthew
    September 19, 2006 at 9:56 pm
    Hi Jerome,
    Set your hardware prefs to 48K. Use the import tool to re-import the audio file you want from the media drive. In the import dialogue, select “convert to 48000 Hz”
    K
