Activity › Forums › Adobe After Effects › How can i do that?
How can i do that?
Posted by Evrard Blom on May 31, 2006 at 6:24 amHi,
I want to ask if it is possible to align particles along a path. If yes can you tell me how? like some quick tutorial?
Thank you
Roland R. kahlenberg replied 20 years, 3 months ago 4 Members · 3 Replies -
Justin Productions
May 31, 2006 at 6:39 amIs it me, I don’t quite remember and I’m too lazy to go check, but I think this feature is in Trapcode Particular 1.5 (upgrade). I remember seing something like this.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional -
Fabiano Peres
May 31, 2006 at 11:46 amYes, he’s right.
Trapcode particular has made a great job at this plugin, If you don’t have it yet go to http://www.trapcode.com and take a look at it, there are video tutorials that will show you how to make it.
But if you cannot afford it, you can use “Particles playground” from After effects, create a mask the shape you want the particles to go and at “Wall- bondary” select the mask as a path, it’s not so realistic as trapcode particular but… -
May 31, 2006 at 4:11 pmWith Particle Playground, you should look into the particle emitter’s position, the use of a Wall (using a closed mask shape), gravity and Kinetic Friction (under persistent property mapper).
Take a look at my particle playground tutorial here at the COW – Fun in Particle Playground Land for insights into, particle emitter position, Wall and kinetic friction.
Cheers
Roland Kahlenberg
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files
