Activity › Forums › Apple Final Cut Pro Legacy › How can i dedicate more of my system resources to FCP
  • How can i dedicate more of my system resources to FCP
    Posted by Chris Zacchia on December 6, 2009 at 10:52 am
    I recently upgraded the amount of Ram in my mac from 1G to 3G. I did this mainly to try to speed up FCP. However when i’m rendering, or encoding i check my system resource allotment and it tells me that FCP is only using 400-450 MB of RAM, while i have about 1.5G idle.
    Does anyone know how i can set my system to dedicate more of my processing power to FCP?
    chris
    Adam Chesbrough replied 16 years, 8 months ago 5 Members · 5 Replies
  • John Pale
    December 6, 2009 at 6:17 pm
    You can’t. FCP is not yet written as a 64bit app, which limits the RAM it can take advantage of. The extra RAM you put in is stll a good idea, as you wiil be able to run apps simutaneously without slowdowns, and also gives more breathing room for the OS.
  • Zane Barker
    December 7, 2009 at 12:19 am
    Yell your not looking at the whole thing here John.
    [John Pale] “FCP is not yet written as a 64bit app, which limits the RAM it can take advantage of”
    Yes that is true BUT final cut pro can still use more ram then what Chris has.
    [chris zacchia] “I recently upgraded the amount of Ram in my mac from 1G to 3G”
    [chris zacchia] “it tells me that FCP is only using 400-450 MB of RAM, while i have about 1.5G idle”
    Chris read this article about ram usage in FCP, but the short story is to use the full potential of FCP you need more then 4GB of ram.
    https://support.apple.com/kb/TA27734
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • John Pale
    December 7, 2009 at 5:45 am
    I am finding typing answers on an iPhone is making them less complete than they ought to be. Thanks for a better answer Zane.
  • Andrew Evans
    December 7, 2009 at 8:22 am
    Rendering and encoding is processor intensive. More ram isn’t going to help you there.
  • Adam Chesbrough
    January 28, 2010 at 1:57 am
    I have 8GB’s and 2.53 GHZ (new macbook pro)…currently exporting a two minute spot shot in 1080p (H264) to 720p (H264)…it is going to take an hour plus (does this sound right?)
    My computer is using 80%-85% of the CPU but 3.05 GB of RAM. I am transitioning from a faster desktop PC as I have had nothing but problems and wanted to start working in final cut pro, with these speeds I’m reconsidering.
    I am selling everything that I own to get a the 12 core mac pro when it drops…this is excruciating.
    Current config:
    Dell XPS 730 H2C
    Quad Core Duo QX9650
    Dual ATI 3870X2 Graphics Cards
    6 GB RAM
    Dual 1 TB Harddrives (RAID O)
    Windows 7 Home Premium
