Activity Forums VEGAS Pro How can I create these 3D effects?
  • How can I create these 3D effects?
    Posted by Ben Win on July 8, 2013 at 12:40 am
    https://youtu.be/wmKj7vt4xRY?t=4m11s
    Go to 4 minutes and 11 seconds (4:11).
    The first thing I wanted to know how to do was to have the 3D sources sit there while the video moves around like a camera would in an exhibit. The only way I know how to do this is the hard way which would be to move every single clip in the exact same motion, so it would look like they’re stationary, however, I was hoping there would be a simpler answer than that.
    Second, I would like to know how I can repeat a clip’s video in a line like in this video: https://www.youtube.com/watch?v=5qziKs4G-L8
    Or to repeat the video to spread out over the screen (tiled) like in here: https://youtu.be/jXASzd3YBX8?t=1m
    Go to 1 minute (1:00).
    Ben
    Thayalan Paramasawam replied 13 years, 1 month ago 4 Members · 4 Replies
  • John Rofrano
    July 8, 2013 at 10:51 am
    [Ben Win] “The first thing I wanted to know how to do was to have the 3D sources sit there while the video moves around like a camera would in an exhibit. The only way I know how to do this is the hard way which would be to move every single clip in the exact same motion, so it would look like they’re stationary, however, I was hoping there would be a simpler answer than that.”
    Hi Ben, The majority of your effects can be handled by learning how to use Track Motion with Parent tracks. I have tutorials about this on my web site:
    3D Parent Motion <– will give you the basics of moving tracks in unison
    Parent Motion Filmstrip <– will show you how to line the videos up
    Feel free to ask me questions here about either of these techniques and I’d be happy to help you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Roger Bansemer
    July 8, 2013 at 1:01 pm
    NewBlue V6 also have a plugin called Tile which can do a whole variety of onscreen multiple images.
    Roger Bansemer – PaintingAndTravel.com
  • Ben Win
    July 8, 2013 at 11:27 pm
    [John Rofrano] “Hi Ben, The majority of your effects can be handled by learning how to use Track Motion with Parent tracks. I have tutorials about this on my web site:
    ~jr
    https://www.johnrofrano.com
    https://www.vasst.com
    Thanks! I’ll be sure to check it out!
    In the video, however, there are different pitch-shifting parts in the whole line. Can I select an already finished pitch-shifted line (there are usually multiple clips with different pitches) and cause them to duplicate side by side to make a line going across the screen?
    And, how can I make the tiled effect? Is there any way I can do it without using plug-ins? I like to do things manually 😀
  • Thayalan Paramasawam
    July 11, 2013 at 11:17 am
    Thank You Sir (Mr.John Rofrano)
    Its help me too.
