Activity Forums Adobe After Effects how can I create a particle vortex effect.
  • how can I create a particle vortex effect.
    Posted by Andrew on October 3, 2006 at 10:55 pm
    I need to make a quick transition out of a pile of leaves. I want it to feel like a dust devil or vortex.
    I have been fiddling with Particular but can seen to figure it out. Help!
    Mylenium replied 19 years, 11 months ago 2 Members · 1 Reply
  • Mylenium
    October 4, 2006 at 3:07 am
    Not sure how exactly you want it to look, but:
    a) Make your leave a 3D layer in a sub-comp.
    b) Animate a spin/ tumble to your needs.
    c) Make that sub-comp a custom particle in your main comp and use one of the split clip methods.
    d) Emit all your leaves at once by keyframing your Particles/ sec. from an extremely high value to 0 over the course of say 3 frames from a box emitter. Use no velocity at all.
    e) Animate Wind and the Radial Field Strength to make them move when you need to.
    Mylenium
    [Pour Myl
