Activity Forums Adobe After Effects How can I create a field that will accept a video (drag and drop)
  • How can I create a field that will accept a video (drag and drop)
    Posted by Zeno Pierre on November 18, 2010 at 10:27 am
    Hi All
    I created a plain square object in After Effects and, in using expressions, I animated it to bounce. I would like to be able to drag and drop a video clip onto that object and have the video take on the actions or characteristics of the object,
    I tries “search” and couldn’t find any discussions on the topic.
    Any suggestions? Or is there another software available to achieve such a task? Or is this too technical for this camper?
    Thanks fro your help.
    Kevin Camp replied 15 years, 9 months ago 3 Members · 2 Replies
  • Frank Feijen
    November 18, 2010 at 10:45 am
    If you mean within after effects: alt-dragging the video from the projectwindow onto the composition (while the square objectlayer is selected in the composition), should replace the layer keeping all expressions, keyframes etc intact.
  • Kevin Camp
    November 18, 2010 at 6:45 pm
    another solution would be to pre-comp the layer (leave all attributes). then you can drag footage/images in to that pre-comp and it will update in the main comp…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
