Activity Forums Adobe After Effects How can I create 40 identical lower 3rds that will have a different text?
  • How can I create 40 identical lower 3rds that will have a different text?
    Posted by Olivier Prudhomme on May 2, 2016 at 3:43 pm
    I need to lower 3rd / ID 30 people in a video. The lower 3rds have to be the same ones animtaion / look wise. Of course I need to update each with the name of the person on camera.
    It is a pretty complicated animation/project with 3 main comps and nested comps.
    When I duplicate the folder contening the comps in the project it doesn’t work as the changes made on Lower 3rd #1 show on Lower 3rd #2….
    Again, it’s 30 lower 3rds so I can’t – or don’t think I should have to – create a project for each person on camera. It would be too time consuming and it wouldn’t make sense AE doesn’t allow for this type of thing.
    Any idea?
    Thx
    Los Angeles – TV Promo Editor – FCP – AVID
    Olivier Prudhomme replied 10 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Brame
    May 2, 2016 at 4:26 pm
    Check this out…
    https://aescripts.com/compsfromspreadsheet/
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Olivier Prudhomme
    May 3, 2016 at 2:44 pm
    I don’t think it will work for my needs…
    thx though
  • Kalleheikki Kannisto
    May 3, 2016 at 6:14 pm
    May 3, 2016 at 6:19 pm
    Don’t know if this applies in your case, but if the text doesn’t have any hugely complex animations by itself, you could prerender the other layers and then make comps that have only the text layers in them and the pre-rendered lower third underneath.
  • Olivier Prudhomme
    May 3, 2016 at 6:34 pm
    they”re preetty complicated animations… with precomps
  • Olivier Prudhomme
    May 3, 2016 at 6:36 pm
    wow thx Dave for taking the time to detail the process.
    Not sure if I’ll understand everything 🙂 but I’ll read and read again! Worth a try
  • Olivier Prudhomme
    May 3, 2016 at 9:06 pm
    Figured it out with co-worker so I thought I’d share the solution:
    I need 20 of the same Lower 3rd animation with different text of course.
    To make it easy to follow let’s say I have ERIK and STEVE that need to be IDd.
    The project requires 1 Main comp and 2 precomp:
    Let’s start with ERIK: ERIK_MAIN and ERIK_PRECOMP_A and ERIK_PRECOMP_B
    1- Duplicate all comp from Project window
    2- Label the new comp and precomp with the new name: ERIK_Main becomes STEVE_MAIN and the precomps become STEVE_PRECOMP_A and STEVE_PRECOMP_B
    3-Dble click the new ID: STEVE_MAIN comp
    You’ll notice that in this new STEVE_MAIN comp, the precomps are still referencing to the ERIK_PRECOMP A and B.
    We need to replace these with the STEVE_PRECOMP A and B
    4-In the timeline highlight/select ERIK_PRECOMP_A
    5-In the Project window highlight/select STEVE_PRECOMP_A then Cmd-Opt / at the same time.
    You should see ERIK PRECOMP A being replaced by STEVE PRECOMP A.
    Do the same with Precomp B.
    You’re done.
