Activity Forums Adobe After Effects How can I change the thisComp.layer(“layername”) by script ?
  • How can I change the thisComp.layer(“layername”) by script ?
    Posted by Supak Suksawat on March 5, 2022 at 4:46 pm
    Now, I get the script like this and I want change the “layername” in thisComp.layer
    original
    FACE[i].transform.position.expression = ‘b=thisComp.layer(“layername”).transform.scale;\
    if(b>[0,100]){ \
    value=value-((b-[100,100])/10) \
    but I want to change like this
    FACE[i].transform.position.expression = ‘b=thisComp.layer(BEYER.name).transform.scale;\
    if(b>[0,100]){ \
    but it didn’t work
    I want to change the “layername” to object.name
    How can I do that ?
    thank you
    Supak Suksawat replied 4 years, 6 months ago 3 Members · 4 Replies
  • Frederic Berria
    March 6, 2022 at 11:40 pm
    You can give a try with the layer.index.
    thisComp.layer(1).transform.scale;
    I guess you defined :
    layer.name=« toto »;
    So use thisComp.layer(« toto »).property(« ADBE transform » ).property(«ADBE Scale »).setValue(1).
    (I think it’s better to use the proper names in case you share your script to a non-English person.)
    Anyway, reading your post, I just want to have a precision : do you try to catch layers inside a precomp ?
    Cheers,
  • Supak Suksawat
    March 7, 2022 at 12:43 pm
    I had the variable BEYER for catch the layer that name “BLACK EYE R” and I want it show in expression by script Umm.. I didn’t want to write like this
    FACE[i].transform.position.expression = ‘b=thisComp.layer(” BLACE EYE R”).transform.scale’
    because I have the variable BEYER that collect this layer that make me want to write
    FACE[i].transform.position.expression = ‘b=thisComp.layer(BEYER.name).transform.scale’
    how can I do like this ?
    thank you.
  • Walter Soyka
    March 8, 2022 at 4:59 pm
    I assume you’re trying using a script to write an expression into a property?
    Two things I see in this code snippet:
    1. It looks like you’re trying to reference a variable inside a string, and expecting it to evaluate; it will not. You need to separate out the string’s pieces and the variable, and concatenate them.
    2. You’re assigning that result to a variable that you’re not actually using or explicitly returning. This will work in this case, but in some cases it can result in an expression error.
    If you have this:
    FACE[i].transform.position.expression = 'b=thisComp.layer(BEYER.name).transform.scale';
    You probably want this instead:
    FACE[i].transform.position.expression = 'thisComp.layer("' +  BEYER.name + '").transform.scale';
  • Supak Suksawat
    March 8, 2022 at 5:11 pm
    Oh, yes this is some thing that I want
    thank you so much
