Activity Forums Adobe Premiere Pro How can I change from letterbox to widescreen?
  • How can I change from letterbox to widescreen?
    Posted by Harrell Williams on May 25, 2012 at 6:27 am
    Hello. I edit with Adobe Premiere CS5. I have video clips that have a black boarder all the way around, which looks like/is a letterbox effect. I want to match my other footage which is HDV 1080p widescreen, and I don’t want to loose any quality. Is there a way to change the letter box effect to widescreen (widescreen, meaning the footage is all the to the edges of the preview/playback windows)? Video formatted as VLC media file (.mpeg).
    These are the specs:
    Type: MPEG Movie
    File Size: 266.9 MB
    Image Size: 1440 x 1080
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:01:57:12
    Average Data Rate: 2.3 MB / second
    Pixel Aspect Ratio: 1.3333
    Thanks.
    Paul Gilmore replied 14 years, 4 months ago 3 Members · 3 Replies
  • Ryan Patch
    May 25, 2012 at 2:40 pm
    It sounds like the video you’re talking about it simply smaller resolution than the rest of your footage / your sequence settings. Just click on the clip and open up the “motion” effect in the effects window. Increasing the size, I bet, will fix your problem.
    If that doesn’t work, could you be more specific about the two different types of footage you have?
  • Harrell Williams
    May 26, 2012 at 8:18 am
    Thanks for the info. I followed your instruction and that didn’t work. The position = 720; scale = 100. These are same settings that are on regular/full size clip. The clip/footage has a black boarder around it and I want to stratch it so that the video is all they way to the edges. See the attached image. Thanks again for responding
  • Paul Gilmore
    May 28, 2012 at 12:26 pm
    This has happened to me to and what I found out was that the footage was shot in 4:3 and not 16:9. Letterbox is the same as widescreen just as AC-3 is the same as Dolby Digital, they are just called different names by different users. Your picture looks like it wasn’t shot in 16:9?
