How can I change 3d object anchor point position in Element 3d?
Hi everyone!
Hi everyone, I have a odd and probably simple question for advanced, but I have a problem with that and I need help. My question is how can i change 3d single object anchor point in “effect control” window in element 3d plugin. I trying to rotate single object, but when doing this, my object is rotating to the bottom point. I need this point in the center of the box, to do it around your axis. How can I do this? I ask for help in this case.
Thanks! ☺
