Activity › Forums › Adobe Premiere Pro › How can I capture HD in Adobe Premiere Pro?
  • How can I capture HD in Adobe Premiere Pro?
    Posted by Bruce Rutland on January 21, 2014 at 7:46 pm
    I’m trying to capture HD through a Blackmagic Teranex 2D box in a 4:3 format for a client, but the settings in PP5 will only allow 16:9.
    This is the only format I can select for HD:-
    “For editing in Motion JPEG format with Blackmagic equipment.
    High Definition 1080 line, 50 fps video (16:9 progressive).48kHz 16 bit audio.”
    Any ideas?
    Thanks in advance.
    Bruce Rutland
    https://www.rutlandproductions.co.uk
    Bruce Rutland replied 12 years, 8 months ago 3 Members · 4 Replies
  • Andrew Kimery
    January 21, 2014 at 8:24 pm
    HD is only 16×9. If you want 4×3 you’ll have to capture in SD. What are the specific requirements from your client?
  • Bruce Rutland
    January 22, 2014 at 3:04 pm
    Hi Andrew, thanks for the reply. I transfer cine film to DVD/digital format. I’m capturing from an MWA FlashSCAN8 machine, through a Blackmagic Teranex 2D box and into Premiere Pro 5. The client not only wants SD files, but also HD. Because the format of cine film is 4:3, PP5 keeps the 16:9 format and drops black pillars each side of the film. I think this is quite acceptable, but the client has asked for the HD to be supplied as a 4:3 file…
    Bruce Rutland
  • Jeff Pulera
    January 22, 2014 at 3:12 pm
    Hi Bruce,
    You need to make it quite clear to the client that HD video is ALWAYS, ALWAYS a widescreen 16:9 format and when converting 4:3 source to HD, it WILL be pillarboxed (black bars on sides). You might have an option to center-crop the upconversion, which will expand the 4:3 source to fill the 16:9 frame, but that further reduces quality and crops some of the original source frame as well…
    Jeff Pulera
    Safe Harbor Computers
  • Bruce Rutland
    January 22, 2014 at 3:17 pm
    Thanks for the very speedy response Jeff!
    That is certainly some very good advice.
    All the best.
    Bruce Rutland
