Activity › Forums › Adobe Premiere Pro › How can I build a database
Posted by Art Thomas on October 19, 2012 at 2:39 amhi,
I have hundreds of clips. In PremierePro CS6 I do not have database capabilities. The only way I can use a database like Microsoft Access, is to export the clips since Premiere only generates virtual clips, and then import them into the database program. Syncing is a nightmare.Is there any other way to do this? Thanks.
Art Thomas replied 13 years, 10 months ago 3 Members · 11 Replies -
Alex Udell
October 19, 2012 at 4:42 amHow about Cat DV?
Alex Udell
Editing, Motion Graphics, and Visual FX -
Art Thomas
October 19, 2012 at 8:43 pmCat DV might work if it could somehow take the clips out of Pemiere and insert them into Cat Dv without having to export them first from Premiere. From what I have read, things can be taken into Premiere, ie. imported, but not go out unless again, they are exported. So it has the same limitations as I described before. If someone knows better, then please let us know.
Great suggestion, thanks.
Alex Udell
October 19, 2012 at 9:35 pmHi Art…
What ultimately are you trying to accomplish?
If I understand that, then maybe I can be of more help.
Thanks…
Alex
Art Thomas
October 20, 2012 at 3:34 amHi Alex,
I want to be able to do two things.The first is to be able to search the clips for tags that describe different attributes of the clip. There are many different tags that can select just one clip. This is the database aspect. Maybe 2 or maybe 10 clips will come up for review for one or multiple tag words.
The second is to be able to scroll/ view through the selected clips to see if a particular one satisfies the requirement for selection. Premiere cs6 does a nice job of letting you do this, but has no data base ( ie. search capability using tags).
It stands to reason that Premiere would have to export a clip to generate an actual clip file that can then be used in many different programs because Premiere maintains source file integrity. But, exporting, then importing into another program and trying to keep up with new clips, and deleted or modified clips will become unwieldy very quickly and create a nightmarish sync problem. My hope was there is some way of using Premieres virtual clips directly.
I guess I would like to know how commercial studios catalog their massive amount of clips for easy retrieval.
Thanks for listening. I hope I was able to provide some clarity of my objectives.
Art Thomas
October 20, 2012 at 3:49 amForgot to mention. The clips are not project oriented. They are standalone , that’s why a database type program is needed.
Alex Udell
October 20, 2012 at 11:43 amHi….
OK….let me try to clear up some confusion I have…
When you say you have thousands of “clips”
Are you referring to clips in the project panel of Premiere Pro?
Are all these in one massive project?Or do you mean you’ve got a thousands of media files on your hard drive?
Or do you mean that you have thousands of media files on your hard drive. You’ve brought them into Premiere Pro and marked them with IN and out? And perhaps made multiple “clips” from the same underlying source media?
Alex Udell
Art Thomas
October 21, 2012 at 2:24 amHi Alex,
Sorry about the confusion.The last one. Source files with sub clips. In and out selections.
Hope that helps.
Alex Udell
October 21, 2012 at 4:17 pmHi Art…
I still think CatDV is the right tool for you….
I’ve asked….
https://forums.creativecow.net/readpost/278/2668
Let’s see what we find out.
Alex Udell
Art Thomas
October 21, 2012 at 9:47 pmGreat! Thanks.
I was also looking at Adolbe Bridge. Can’t get the Premiere clips (I call them virtual clips) into that either I guess.
Gabriel Sanchez
October 26, 2012 at 2:24 pmAdobe Bridge lets you add tags to all the clips, but don´t import them from Premiere Proyect pannel, but from your hard disks.
Have you tried to do it (in/out and tagged) in Prelude?
Regards
