Activity › Forums › Adobe After Effects Expressions › How can I avoid using ‘eval()’ in my script?
  • How can I avoid using ‘eval()’ in my script?
    Posted by Kevin C. burke on April 15, 2015 at 12:34 am
    Hello,
    I’m trying to get After Effects to see a property path string (i.e. (‘Contents’)(‘Group 1’)(‘Contents’)(‘Rectangle 1’)(‘Contents’)(‘Rectangle Path 1’)(‘Position’)) as a property.
    I can do this with eval(), but I have been told that this is bad practice and could be potentially used maliciously.
    In my research for avoiding eval(), I’ve seen people suggesting passing strings to ‘window’ which allows the browser to recognize a function, variable, or whatever. Does something similar exist for After Effects and ExtendScript? If not, how can I get After Effects to see a string as a property path?
    Thanks! 🙂
    Kevin C. burke replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
