Activity Forums Adobe After Effects How can I apply an animated gradient to all sides of a 3D shape layer?
  • How can I apply an animated gradient to all sides of a 3D shape layer?
    Posted by Roman Burminskyy on July 13, 2025 at 5:32 pm
    Hey everyone,
    I’m working on a 3D podium made of three extruded shape layers (using the advanced 3D shape layer options in AE, not C4D renderer). I’d love to make each step look like a glowing LED panel — like a huge animated gradient screen you’d see in a shopping mall or on a concert stage.
    I already created an animated gradient (using a solid + adjustment layer inside a precomp), and I want to map that onto each side of the 3D shape — top, front, side, etc.
    I’ve tried using Set Matte, precomping the gradient and placing it in 3D space, using Collapse Transformations, and a bunch of other tricks… but I can’t figure out how to apply the gradient cleanly to all the visible faces of the extruded shape.
    Is this even possible in After Effects (advanced 3D), or should I give up and rebuild the podium from solids or in a 3D app like Blender?
    I’d prefer not to switch to Cinema 4D or fully rebuild everything if there’s any workaround — even if it’s a bit hacky. Appreciate any help or clever AE solutions.
    Thanks in advance!
    John Martin replied 1 year, 1 month ago 2 Members · 5 Replies
  • John Martin
    July 13, 2025 at 6:32 pm
    Yo Roman! Send me the project file so i can inspect exactly where you’re at and i’ll record a custom tutorial with a simple solution i have in mind, talk soon!
  • John Martin
    July 13, 2025 at 9:07 pm
    Here’s a preliminary tutorial for you, i hope this idea helps get closer!
    https://youtu.be/9qyqcmiYTRg
  • Roman Burminskyy
    July 13, 2025 at 9:56 pm
    Thank you very much for answer! I have already started making pre-compositions out of desperation.
  • Roman Burminskyy
    July 13, 2025 at 9:57 pm
    This is a cool tutorial. I’ll try it as well!
  • John Martin
    July 14, 2025 at 6:42 am
    you’re welcome!
    Pro tip: when you create the masks, recreate the faces of the 3d shape you need to wrap the animation on, as close as possible;
    That way, you’ll just need to position the shapes on each face with very low pain since the aspect-ratio is already right!
