Activity Forums Adobe After Effects How can i align my text on this airline
  • Hanna Dean
    April 29, 2016 at 1:27 pm
    will anybody comment on this cheers.
  • Cassius Marques
    April 29, 2016 at 5:44 pm
    Try the mesh warp or the reshape plugin. But if the airplane rotates too much, you end up having trouble keeping it in shape.
    Cassius Marques
    http://www.zapfilmes.com
  • Kalleheikki Kannisto
    April 29, 2016 at 8:12 pm
    Make a precomp with a tight crop around the text, larger than you need at any point in the footage. Use Mesh Warp with 1 column and 1 row and give it the needed shape that follows the contour, but discounts the perspective — basically that missing additional distortion coming from the roundness of the plane surface that perspective distortion doesn’t provide. Then use corner pin to stick it on the plane. I assume you’re tracking the current text for corner pin.
    If there is a lot of “turn-table” motion in the footage you can animate the Mesh Warp.
  • Hanna Dean
    April 29, 2016 at 8:20 pm
    yes sir am currently using corner pin data using mocho pro
