Activity › Forums › Adobe After Effects › How can i add light to text opacity transition like this ?!
Posted by Bedo Nada on July 14, 2017 at 3:08 pmHi,
https://www.youtube.com/watch?v=AXf1emisjqk
Greg Gesch replied 9 years, 1 month ago 4 Members · 4 Replies -
John Cuevas
July 14, 2017 at 8:35 pmWhat light are you talking about? I see the transition come in with large blur and dissolve out with a large blur.
Johnny Cuevas, Editor
ThinkCK“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Bedo Nada
July 14, 2017 at 9:16 pmSorry, i’m new in after effects, So i can’t explain very well
How can i do a large blur like this ?!
Richard Garabedain
July 14, 2017 at 10:50 pmWow…why dont you learn the basics of after effects before coming on here…Your telling us you dont know how to use a blur or change the opacity..that means you know nothing…nothing at all.
Greg Gesch
July 15, 2017 at 3:03 amHi Bedo, there are blur effects which you add to your text layer, and the text layer has an opacity setting which you can keyframe. If this makes no sense then go through these very old but very short basic tutorials so you get some idea of how the program works:
https://www.videocopilot.net/basic/
after these you should be able to do the effect you want – and a lot more.There is also an extremely good series of beginners tutorials by Andrew Devis here on Creative cow which go into more detail.
