Activity › Forums › Boris FX Particle Illusion › How can i add keyframe animation before frame 1?
  • How can i add keyframe animation before frame 1?
    Posted by Stuuart on June 8, 2006 at 9:48 pm
    any way to do this?
    I’m using the tornado effect, coming from a woman’s finger, who is making a circular motion, & i need shot 2 to be “in progress” after shot 1. Preroll doesn’t help me because there is no animation at the start of shot 2, so the tornado is a straight line until the motion catches up with the effect.
    I tried exporting/importing the keyframes from shot 1 into shot 2, but again, i need them to be inserted before frame 1, so at frame 1, the effect is being animated.
    Also, i’ve never been able to figure out how to select all keyframes & slide them one way or the other. Is this possible?
    Love the new site, & the emitters keep rockin.
    thanks
    Stuart Roholt
    Digital Effects Supervisor
    NBC Studios/Passions
    Stuuart replied 20 years, 3 months ago 2 Members · 2 Replies
  • Elvis Deane
    June 9, 2006 at 5:47 am
    Other than changing the Frames to Preload, there aren’t any settings that allow for animation before frame 1.
    There’s no way to slide all the keyframes around, but if you paste an emitter at a keyframe other than frame 1, all the keyframes will move too. So if you paste an emitter at frame 31, a key that was at frame 5 originally will now be at frame 35. That’s probably the best way to move all the keyframes in one shot.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • Stuuart
    June 9, 2006 at 3:54 pm
    thanks elvis, that might just work for this. I love this program & use it ALOT, but one day, my head is going to explode trying to figure out a workaround 😉
    Maybe i’ll do the effect in PI…
    Stuart Roholt
