Activity Forums Adobe After Effects How can I add contrast to help roto?
  • How can I add contrast to help roto?
    Posted by Anthony Sneed on October 16, 2021 at 6:00 pm
    For the life of me, I cannot remember how I used to add contrast to a layer then pre comp and I was able to roto that version, then freeze the roto work and remove the contrast. For some reason, each time I take it to the layer level the contrast is not on there.
    Any advice for how to do this properly would be much appreciated!
    Greg Gesch replied 4 years, 10 months ago 2 Members · 1 Reply
  • Greg Gesch
    October 17, 2021 at 1:23 am
    Hi, I usually add the contrast and other necessary adjustments by adding them in the precomp, not the main comp. Is that the issue?
