Activity Forums VEGAS Pro How can I add arrows and camcorder effects?
  • How can I add arrows and camcorder effects?
    Posted by Tinfish on September 15, 2005 at 9:33 am
    Dear Vegas experts,
    I’m looking for a couple of effects for a video project.
    I’d like to add an arrow to the video as a means to point
    things out. There are no arrows in the Cookie Cutter effects
    in Vegas-5 that I can see. So is there a script somewhere
    that would do the trick?
    Also, I once seen a games video where the chap had added
    a camcorder recording effect which looked very impressive.
    The effect, or mask, was simply a flashing word ‘rec’
    (for recording), and a camcorder-type curved frame at each
    corner of the video. Any idea if such an effect exists for
    Vegas-5.
    Thanks in advance,
    Tin
    (UK)
    Tinfish replied 20 years, 11 months ago 4 Members · 5 Replies
  • Barend Jasper
    September 15, 2005 at 12:47 pm
    In Photoshop you can easily draw an arrow on a transparent background (make the image size 756×568 pixels). Save as PNG file and import in Vegas.
    For the rec text: add a new title and type rec. Make the text red and place in corner. Make the event one sec long and copy it as many times as you want, having one sec of empty space between the events.
    Good luck,
    Barend
  • Tinfish
    September 15, 2005 at 1:34 pm
    Thanks Barend.
    Quick question. When I import the file from PhotoShop to Vegas, will it appear
    in the Cookie Cutter section ?
  • Mike Kujbida
    September 15, 2005 at 2:10 pm
    Select the Wingdings font in Vegas titler. There are several different arrow styles there to choose from. I did this several times last year for construction students wanting to point out specific things on house building project videos.
  • Edward Troxel
    September 15, 2005 at 4:50 pm
    [Tinfish] “When I import the file from PhotoShop to Vegas, will it appear
    in the Cookie Cutter section ?”
    NO. I recommend you use Mike’s technique of just using a text arrow. It can be rotated and resized as needed via Pan/Crop.
    Edward Troxel
    JETDV Scripts
  • Tinfish
    September 18, 2005 at 3:28 pm
    Thanks. I’ll try that, plus Mike’s tip as well.
    Once again, great forum. Much appreciated.
    Tin
