Activity Forums Apple Final Cut Pro Legacy How Can I Achieve This Transaction???
  • How Can I Achieve This Transaction???
    Posted by Dyce Jackson on July 19, 2010 at 3:42 am
    I am very new to video editing an FCP. I am doing a wedding video for a friend. I put a few clips together for the intro and added an additive dissolve. I loved the effect it achieved it was kind of a flash & burn effect. But when I rendered the clips, they just look like a plain cross dissolve. I refuse to use a plain dissolve after seeing it with the other effect.
    I did a screen recording of it and uploaded it here:
    https://www.youtube.com/watch?v=Xn83Oik5Cec
    I know the quality is horrible but I hope you get the idea. Can anyone tell me how to achieve this effect? Or know of a plugin that will do it?
    Please Help
    Thomas Morter-laing replied 16 years, 2 months ago 5 Members · 5 Replies
  • Sascha Engel
    July 19, 2010 at 8:51 am
    One possibility could be, that when you rendered it, it limits the whites to 100%. Try once to go into the Timeline Preferences (Apple + ‘0’) and set the Render Settings to “SuperWhite”. Does that change the results?
    Sascha
  • Sascha Engel
    July 19, 2010 at 8:54 am
    Can you please also post a screen shot of the rendered version you did not like?
    Thanx.
    Sascha
  • Mark Suszko
    July 19, 2010 at 1:49 pm
    Or you could just put in 15 frames of white, and then put 10-frame dissolves on either side of it….
  • Thaxter Clavemarlton
    July 19, 2010 at 2:06 pm
    [Mark Suszko] “Or you could just put in 15 frames of white, and then put 10-frame dissolves on either side of it….
    That can (basically) be achieved using a single transition called “Dip to Color Dissolve” (make the color white.)
  • Thomas Morter-laing
    July 22, 2010 at 1:01 pm
    Or a flash transition and use the transition parameters to reduce the maximum exposure…
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Production Assistant, Grace Productions
    Degree; TV Production
