Activity › Forums › Adobe After Effects › How can I achieve it
Posted by Edwin Cold on April 2, 2025 at 10:06 pmHello, good afternoon, how are you? Could any of you guide me on how to achieve this text effect? Please. Thank you.
Alex Todorov replied 1 year, 5 months ago 4 Members · 5 Replies -
Graham Quince
April 4, 2025 at 9:29 amYou can download a model of a phone from somewhere like Sketchfab.
You can create a text layer and add a glow.
If you then precomp this text layer and use it as the source for CC Environment, you should be able to rescale the text until you achieve the an accurate reflection.
Alex Todorov
April 4, 2025 at 1:35 pmHello to archive this text glow effect you need:
1. Add Glow effect:
>Glow colors>A&B Colors
>Color A>Set color that you need
>Color B>Set color that you need
>Color looping>Sawtooth A>B
>A&B midpoint>0 or 100%
>Glow Radius>the one that you need
>Glow Intensity>the one that you need
2. Crop text into 2 parts with mask
3. In glow effect>Compositing options(in timeline)>+>Mask 1
4. Dublicate Mask and move point to cover other part of the text
5. Dublicate Glow effect >Compositing options(in timeline)>+>Mask 2 (Instead Mask 1)
>Color A swap with >Color B
6. Dublicate 2 Glow effects and for both:
>Glow Radius>decrease
>Glow Intensity>increase
7. And to remove sharp edge on masks edges you need to make 2 Masks>Feather>a little bit more
John Martin
April 4, 2025 at 4:38 pm -
Edwin Cold
April 4, 2025 at 8:01 pmWooowww, thank you very much Alex Todorov, excellent tutorial, very grateful for your interest and your answer.
