Activity › Forums › Avid Media Composer › How can deletwe several clips
  • How can deletwe several clips
    Posted by Olivier Prudhomme on September 9, 2014 at 2:58 pm
    In my workflow I have complex sequences that I need to clean up everyday.
    How can I delete several clips at the same time if there are NOT above each other?…
    So far all I found is the in/out–> lift function
    When I use the select tool or opt-lasso and hit delete it takes several tries to get rid of the clips because Avid seems to delete the effects first…
    I waste so much time.
    Thanks for helping!
    Olivier Prudhomme replied 12 years ago 2 Members · 2 Replies
  • Joshua Hume
    September 9, 2014 at 4:34 pm
    You might be able to map the remove effect command to the keyboard, then you could select your clips with the direct selection tool, hit Remove Effect, which will work on all the selected clips, and then hit delete.
  • Olivier Prudhomme
    September 11, 2014 at 6:13 am
    I actually found a faster way (less key strokes)
    While select tool is active, click on the clip or multiple select using Cmd-Click and then Cmd-X as in “cut”
    Works like a charm!
