Thanks for responding!
Oh, a Matte?
I’m rather new to AE so I may not know the nomenclature yet. I used to be on Vegas but trying the Adobe tools out now.
In trying to create this, a Matte, I’ve been adding a new layer on top of an existing footage – either solid or shape layer – and used the ellipse tool to create an ellipse which will constitute the ‘vignette’ shape. I run into alot of problems in doing so.
For example, the ellipse tool creates a solid shape with a solid edge. Not a gradual transition from transparent to black.
The only way I found to create a gradual ‘edge’ is to create a mask and draw an ellipse shape onto it, and use the mask controls to “feather” the shape edge. But if I do that, then the shape can’t be moved independently over the canvas.
And if I use a mask on a shape layer, then I can’t get the shape to blend onto the underlying layer.
That’s kindof where I get stuck and don’t know where else to look for a solution. I haven’t found anything immediately useful in the FX list either. I may be spoiled from Vegas too, because it is user friendly to the point of oversimplification sometimes. So, maybe I’m just going about this a totally wrong way.
