Activity › Forums › Adobe After Effects › How are these detailed strokes done in After Effects?
  • How are these detailed strokes done in After Effects?
    Posted by Josey Zadoria on January 3, 2018 at 5:37 pm
    Hello Anyone:
    I am currently working on a project that requires creating these moving lightning bolts. As you can see from my attachment, there are two that I am wondering about. In particular, if you notice the lines going through the lightning bolts that gives them the appearance that they have a dashed line element to them, also the red square one has the same type of angled lines too, I am wondering how this is achieved in After effects. I thought I could do these using shape layers then add trim paths along with dashed lines, but that doesn’t seem to work because I don’t know of a way to make the dashes angled. So I am not sure how this is achieved, but I see this detail in a lot in vector animations and I would like to know how it is done. My last resort is creating them in illustrator and then animate them as a path reveal in After Effects. If anybody has a better way in how to achieve this in after effects, I certainly would be interested to know. So thank you in advance for any advice or suggestions.
    Best
    Josey
    Josey Zadoria replied 8 years, 8 months ago 3 Members · 4 Replies
  • Mark Whitney
    January 3, 2018 at 5:56 pm
    I know a few new scripts have come out recently that does this sort of thing.
    Here’s one but there are others:
    https://aescripts.com/ouroboros-2/
    I just searched on Stroke, but explore.
  • Kevin Camp
    January 3, 2018 at 7:39 pm
    the venetian blind effect is goo at making stripes… set the transition completion to around 50% and adjust the angle and width properties as needed.
    you can add that effect to either a shape layer or a layer suing the stroke effect.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Josey Zadoria
    January 4, 2018 at 5:39 am
    So in other words, there is no real answer to this without having to pay for something such as a script?
    Anyway, thanks for the suggestion i will try to look for more.
  • Josey Zadoria
    January 4, 2018 at 5:45 am
    Thank you! Problem solved. That seemed to work perfect.
