Activity Forums Adobe After Effects How are the army clones in this effect achieved?
  • How are the army clones in this effect achieved?
    Posted by Jane Doe on April 9, 2015 at 11:00 pm
    How would you achieve this clone effect in after effects? Only way I’ve seen before is simply keying the footage and multiplying the layer. But in some of these shots you can see thousands of clones, they can’t have multiplied the layer that many times! There must be an easier way?
    https://youtu.be/Sxks3Z6QByc
    Jane Doe replied 11 years, 5 months ago 2 Members · 3 Replies
  • Jane Doe
    April 10, 2015 at 8:14 am
    Because handling 1,000 layers would take a lot of time and processing power. It would be much easier if you could apply a motion tile kind of effect.
  • Derek Boettcher
    April 10, 2015 at 3:58 pm
    You can also use a particle emitter like trapcode’s particular and use a video clip as the particle. You should be able to offset the time on it too if you want it to look like an army vs a repeated image.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Jane Doe
    April 10, 2015 at 5:47 pm
    Thanks Derek! That was exactly the solution I was looking for. I never thought to try Particular but it only took a few minutes to create a fantastic army/clone effect! Awesome!
