Activity Forums Adobe After Effects Expressions how apply inertial bounce on parented layer
  • how apply inertial bounce on parented layer
    Posted by Fernando Huezo on May 20, 2015 at 5:38 pm
    Hi there!
    I need help with something
    I want know how to apply a inertial bounce expression on parented layer
    I tried only apply the expression but it does not work, only using keyframes in the own layer.
    Some idea?
    Fernando Huezo replied 11 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 20, 2015 at 7:22 pm
    Assuming the keyframes are on the layer’s parent’s position property, something like this could work:
    freq = 3;
    decay = 5;
    p = parent.transform.position;
    n = 0;
    if (p.numKeys > 0){
    n = p.nearestKey(time).index;
    if (p.key(n).time > time) n--;
    if (n > 0){
    t = time - p.key(n).time;
    p1 = toWorld(anchorPoint,p.key(n).time);
    p0 = toWorld(anchorPoint,p.key(n).time - .01);
    amp = (p1 - p0)/.01;
    w = freq*Math.PI*2;
    value + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
    }else
    value
    Dan
  • Fernando Huezo
    May 20, 2015 at 8:10 pm
    Its works!
    I just change the P value for the slider that control the X position, Here is where are the keyframes, I guess that is much easier if I apply the values on the null position and define the lowest and highest distance.
    Thank you very much!
