Activity Forums Avid Media Composer how 2create pre-keyed composite ready footage,avid to illustrator and AE workflow
  • how 2create pre-keyed composite ready footage,avid to illustrator and AE workflow
    Posted by Alyousha on May 26, 2007 at 3:20 pm
    Hello, I done a blue screen scenes (3hours) and now I need to do two things, back up my footage as composite ready and pre keyed into DVD, and I need to figuer out a workflow technique between avid, illustrator and after effects, the footage is shot on sony z1 as HD 1080/50i (mxf i think for HD,notOMFI) I don’t need to import the footage again to avid from illustrator or after effects, its a one way ticket from avid to adobe, is the solusion for the two problems is in one formate? like tga? but how. many thanks for your help.
    Al
    Michael Hancock replied 19 years, 3 months ago 2 Members · 1 Reply
  • Michael Hancock
    May 29, 2007 at 7:15 pm
    If you’re just wanting to take the footage from Avid to After Effects for compositing and keying, and you’re working on all of this on the same machine–capture in Avid, export as a Quicktime Reference file. It will point to the MXF on your media drives but After Effects will read it as though it’s a quicktime. To take it to Illustrator, export from AE to Illustrator and back again.
    If you’re exporting from Avid, burning to a Data DVD, an dtaking this to another system for the AE and Illustrator work, you can export standalone quicktime files from Avid. I would do Uncompressed or the Animation codec–3 hours is a lot though. Be prepared to wait awhile for the export, export in chunks, and be ready to burn a boatload of DVDs.
    You could also do Targa sequences–they play nice with AE and Illustrator, but it also takes a while to export and will take up a lot of space. Burning them to a DVD would take A LOT of DVDs, and again–you’ll have to break it up into chunks. I suggest sending them to an External Drive and just taking the drive to your AE/Illustrator workstation. For the cost of all of these DVDs, you can get a decent sized External Drive. It will make your life much easier.
    Does this help?
    Michael.
