Activity Forums Adobe After Effects hour:minute:second counter in AE
  • hour:minute:second counter in AE
    Posted by Michael Paul on August 11, 2009 at 1:45 pm
    Hello
    I want to animate a counter that reads like this 00:00:00 which is hours:minutes:seconds
    So far the only way I know how to animate numbers is the NUMBERS effect. Still I have no idea how to animate my whole thing with it.
    As in: If seconds is 69 the MINUTE counter needs to jump to 01 and the second counter must jump to 09.
    How do I do this?
    Also I just want to enter one value on one key into my counter say “00:05:30” and then I want AE to animate from say “00:00:00” to “00:05:30”.
    Any idea?
    Thanks a million
    Michael Paul replied 17 years, 1 month ago 2 Members · 8 Replies
  • 8 Replies
  • Chris Brearley
    August 11, 2009 at 2:08 pm
    If you set the type in the drop down menu to time doesn’t that do what you want?
  • Michael Paul
    August 11, 2009 at 2:20 pm
    i get my 01:09 but i dont know how to get it with hours as well so it’s 00:01:09. even if i change the ammount of digits. otherwise its working great. i just need that for hours
  • Chris Brearley
    August 11, 2009 at 2:25 pm
    Could you put the hours on a different layer and animate that separately? More hassle I know than doing it on one layer but it should work.
  • Michael Paul
    yeh i guess
    i mean TIME works great but its a shame its only MINUTES:SECONDS
    no way to link that to hours?
  • Chris Brearley
    August 11, 2009 at 2:28 pm
    Yeah you could use an expression to link them I suppose. Pick whip the hour to the minutes and divide by 60 (/60) I think.
  • Michael Paul
    August 11, 2009 at 2:36 pm
    thanks a lot for your help!
    “Pick whip the hour to the minutes and divide by 60 (/60) I think. ”
    how exactly does this go? ive never used expressions
  • Michael Paul
    August 12, 2009 at 7:41 am
    Haha this is so obvious. I can’t believe I didn’t think of this myself. Thanks a million for this great help! 🙂
  • Michael Paul
    August 12, 2009 at 9:42 am
    This sadly doesn’t work as nicely as I hoped it would. If I pick TIME CODE it will run automatically by itself from the start and I can’t tell it “BE 00:00:00:00” at any point in time. Sure I seem to be able to animate it with Value/Offset… but I am not able to set it to zero at any point.
