Activity Forums Maxon Cinema 4D Hotkey 1,2,3, Not Working
  • Hotkey 1,2,3, Not Working
    Posted by Jeff Goin on June 24, 2015 at 9:29 pm
    This is weird.
    My 1,2,3 hotkeys are not working. Win 8. R15.064.
    I’ve deleted the preferences folder and restarted the computer to have it return to defaults.
    I’ve checked in the Window|Customization|Customize Commands and “Rotate Camera” shows that 1 is a valid hotkey for rotate. ALT-LMB works.
    Right now I’m stuck having to move my mouse up to the move/zoom/rotate buttons.
    I got the other suggestions above from other posts on the topic but none of them seem to be helping.
    Any ideas?
    Jeff Goin
    Educational Material For Aviation
    FootFlyer.com
    Jeff Goin replied 8 years ago 4 Members · 5 Replies
  • Adam Trachtenberg
    June 24, 2015 at 10:20 pm
    Dumb question, but do those keys work in other applications?
    In the meantime, you can use Alt + LMB (rotate), Alt + MMB (move), and Alt + RM (zoom).
  • Jeff Goin
    June 24, 2015 at 10:31 pm
    Adam,
    Thanks.
    Yes, I’m using the other hotkeys; they’re just not as quick.
    No, they don’t work in any other application that I commonly use (Photoshop, QuarkXPress, Premiere, Corel Draw).
    Jeff Goin
    FootFlyer.com
  • Quyen Nguyen
    August 20, 2018 at 8:55 am
    Were you able to fix it yet? I’ve got the same problem on R17 Windows 10.
  • Steve Bentley
    August 20, 2018 at 5:23 pm
    I find the hot keys get lost (Win7) frequently. If you goto to Window/Customization/Customize commands and create a new hot key or remind a standard one what it should be, the rest will wake up and behave.
  • Jeff Goin
    August 22, 2018 at 10:03 am
    Unfortunately I never got the 123 keys to work. I’ve acclimated to using different shortcut keys. CTRL-SHFT-LeftMouseButton for moving the view L/R Up/Dn, Alt-LeftMouseButton and Alt-RtMouseButton for zooming. I may have had to set one of these up in Maxon where it allows you to set your own shortcuts.
    Jeff Goin
    FootFlyer.com
