Activity › Forums › Adobe Illustrator › hot text
hot text
Posted by Sean Wilms on March 25, 2014 at 12:55 amSean Wilms replied 12 years, 5 months ago 2 Members · 3 Replies -
Vincent Rosati
March 27, 2014 at 9:15 pmIt looks like the issue might be in achieving the warping of the text glyphs.
I’m guessing that you’ve tried Text on Path.Try expanding your text, than either…
Object / Envelope Distort / Warp: Arc
or manually with…
Object / Envelope Distort / Warp: Mesh (1 row, 2 columns)
The two words would be created in 2 operations, one for the upper and one for the lower.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Sean Wilms
April 1, 2014 at 2:10 pmyes I tried textmon a path I will give your suggestion a try
thank you!
Sean Wilms
April 1, 2014 at 3:01 pmThank you Vincent your advise worked perfectly the expand type did the trick, I was using envolope-make with upper to get the effect but it doesn’t work with compound objects.
thanks a lot for your help
