Activity Forums Apple Final Cut Pro Legacy hot switching express card slot
  • hot switching express card slot
    Posted by Gary Gowman on October 4, 2008 at 12:14 am
    We are editing a project on a MacBook Pro with FCS2 and need to know if we can hot switch the new Matrox MXO2 in the Express slot? We need the slot to also ingest files from the Sony SxS memory cards shot with a Sony XDCam EX camera. After transferring the clips to a FW 800 drive connected to the MacBook, we then need to plug the MXO2 back in to edit with an external monitor, like a 42″ Plasma and maybe another 23″ monitor connected to the extra DVI out on the MacBook. We haven’t bought the MXO2 yet and do not want the older MXO.
    Gary
    Jeremy Garchow replied 17 years, 11 months ago 4 Members · 5 Replies
  • Zane Barker
    October 4, 2008 at 5:11 am
    To be safe I would close out final cut first.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Russell Lasson
    October 4, 2008 at 5:23 am
    Also, you may need to power down the MXO2 before you unplug it. I haven’t used it, but I have a eSATA card that requires that. Sometimes, I have to restart to get it to work right.
    -Russ
    Russell Lasson
    Ridgeline Digital Cinema Mastering
    Universal Post
    Salt Lake City, UT
  • Gary Gowman
    October 4, 2008 at 1:38 pm
    thanx. i kind of felt that my be the issue. is it possible to just say unmount like we do with fw drives? i have only used express for sxs cards. anyone out there using the new mxo2? i don’t see much acytvity on the cow matrox forum. so i am asking here hoping for answers. shane, do you know?
    gary
  • Russell Lasson
    October 4, 2008 at 2:49 pm
    I haven’t used the MXO2, but I looked it up how the card mounts in their manual online. It works the same way as my eSATA card. Check out page 8 of the manual.
    As I said, this isn’t a big deal, and it should work most of the time, but there is the possibility of needed to restart every so often to get it to mount properly.
    So it’s less reliable than just mounting firewire drives, but probably not by much.
    -Russ
    Russell Lasson
    Universal Post
    Salt Lake City, UT
  • Jeremy Garchow
    October 4, 2008 at 8:41 pm
    Usually when you insert an Express Card in to the MBP, you will get a little icon in the top right corner of your Mac (next to the clock). Simply select that and choose to safely eject the card. Do the same with your SXS cards. I haven’t used the MXO2 but I imagine it would operate in this way.
