Activity Forums Blackmagic Design Hot signal to monitor???
  • Hot signal to monitor???
    Posted by David Roth weiss on August 21, 2006 at 6:24 pm
    After doing some recabling, my componenet out from my Extreme card directly into my broadcast monitor is displaying a hot signal similar to what you might expect to see out of a VCR when the 75ohm terminator is in the wrong position. Problem is, the monitor has no 75ohm terminator switch. I have tried everything I can think of, even reinstalling BM dirvers etc, but I’m still getting this hot signal, only on the broadcast monitor BTW, not the FCP viewers. Any ideas???
    TIA,
    DRW
    Bob Zelin replied 20 years ago 2 Members · 1 Reply
  • Bob Zelin
    August 21, 2006 at 10:30 pm
    I have many suggestions –
    1) try a different monitor
    2) rent a waveform monitor to observe the level coming out of the Blackmagic card.
    3) rent a professional monitor (that has 75 ohm termination
    It is very very unlikely that the Blackmagic card has a problem – but you never know. That is what test equipment is for.
    Bob Zelin
