Activity › Forums › Apple Final Cut Pro Legacy › Hot key to export stills from FCP??
  • Hot key to export stills from FCP??
    Posted by Jason on April 26, 2005 at 3:13 am
    Hi, what’s the absolute fastest way to export jpeg stills from FCP. It’s a task I need to do over and over and I can’t find a way to achieve the task efficiently. Any suggestions? Thanks,
    jason
    Jason replied 21 years, 5 months ago 2 Members · 2 Replies
  • Jason Lyons
    April 26, 2005 at 4:17 am
    Hello-
    Two things come to mind. First, you can map a key like “shift-O” (I use ‘O’ for output) to the file menu’s export using quiktime conversion – so that all you have to do is select a frame and type shift O – then you’ll get the export dialog box. This works well for one or two quick exports.
    Secondly, If you are trying to export several JPEGS I suggest using batch export. Do so by first creating a bin & name it JPEGS to export. Next, select the frame you wish to export and subclip or drag the clip from your viewer or canvas (which ever you are pulling stills from). Name each of the 1 frame subclips in your new bin. Highlight the bin and select batch export from the file menu. Once batch export opens, click on the settings tab and choose – Export to still image and set your settings as you normally would under this dialog menu. Select your destination and click export.
    Hope this helps
    jason
  • Jason
    April 26, 2005 at 4:56 am
    Excellent, that sounds great. The batch export method is the sort of thing I was hoping for, thanks again.
    jason
