Activity › Forums › Adobe After Effects › Hot key for specific effect (Levels)
  • Anders Hattne
    April 3, 2009 at 6:00 pm
    …if it’s the only effect you ever apply (!!) you’ve got Ctrl+Alt+Shift+E for the last effect applied.
    I wonder, since you can customize the keyboard shortcuts maybe there’s a way you could make your own shortcut for Levels?
  • Riccardo Sinti
    April 3, 2009 at 6:40 pm
    Thanks, i do know that last effect shortcut, but there is always one or two effects between levels and the next time I use it.
    Thank You
  • Peter O’connell
    April 5, 2009 at 11:46 am
    Hi, if you make a script that applies that effect to the layer, you can then apply a keyboard shortcut to that script.
    Pete
    roguekeyframe.com
