Hot key for “drag a comp down onto the ‘Create a New Composition’ icon”?
I need to make many many successive strings of nested comps and was hoping there’s some hot key that can do so.
Like, I select a comp in the project window, then hit a hotkey, then a new comp that it’s nested in is created. Similar to the command File > New Comp from Selection. Unfortunately that doesn’t work for comps, only other assets.
Thanks in advance for any help.
