Activity › Forums › Apple Final Cut Pro Legacy › Hot key fo making preassigned duration clips
  • Hot key fo making preassigned duration clips
    Posted by Kevin on August 22, 2007 at 1:06 am
    Hi list,
    Is there a hotkey or any automated method for marking in and outs of a set duration in the viewer and inserting that clip in the timeline. I normally do this by maring in/out and inserting but it would be dreamy to be able to scrub through footage in the viewer and hit just one key to get a preset lenght clip added to the timeline. Might be wishful thinking……
    Many thanks in advance
    Kevin replied 19 years, 1 month ago 3 Members · 3 Replies
  • Tom Wolsky
    August 22, 2007 at 1:11 am
    Might be able to do it with QuicKeys. I don’t know enough about it. Otherwise set the In point, click in the duration box, type in 5. and enter (for a five second clip) and press F10.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Martin Baker
    August 22, 2007 at 5:27 pm
    Also you can save yourself a click in the duration box by pressing Tab with the Viewer or Canvas window active.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
  • Kevin
    August 24, 2007 at 10:41 am
    Thank you for the Quickeys suggestion too Tom.
    Perhaps this is also a good way around making selects from multiple viewers and accidently using the insert key for any viewers other than the main one – I make this mistake constantly and have never understood FCP’s rationale for not allowing you to use the insert or overwrite hotkeys from any active viewer.
    Many thanks again.
    Kevin
