Activity Forums Panasonic Cameras Hot Connection
  • Hot Connection
    Posted by Nitin Sawant on July 3, 2008 at 4:24 pm
    I am using the DVX 100B for a few years but suddenly I have a very hot connection on my XLR input. I have to keep the input to 2 or 3 to record and then when the sound drops the camera does not pick up anything.
    No problem when I use the on camera mic.
    Any suggestions. Do any of the settings need checking.
    Thank You
    Nitin
    Steve Wargo replied 18 years, 2 months ago 3 Members · 4 Replies
  • Noah Kadner
    July 3, 2008 at 7:28 pm
    [Nitin Sawant] “I am using the DVX 100B for a few years but suddenly I have a very hot connection on my XLR input. I have to keep the input to 2 or 3 to record and then when the sound drops the camera does not pick up anything.
    Thank You”
    Probably a loose connection internally. I’d get it in for a service repair. Probably not too expensive and that camera’s age it’s not a bad time to go for a full cleaning/checkout while your at it.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Steve Wargo
    July 7, 2008 at 3:51 am
    [Nitin Sawant] ” I have a very hot connection”
    Um, do you meant HOT temperature or HOT level?
    If you mean LEVEL, check the front of the camera to make sure that it is switched to MIC and not LINE.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
  • Nitin Sawant
    July 7, 2008 at 4:01 am
    I am using an XLR input so should I not be using line?
    Nitin
  • Steve Wargo
    July 18, 2008 at 5:40 am
    Actually, the type of connector does not determine the level of the feed. If your XLR is connected to a microphone, you’ll have MIC level. If it’s coming from something else, it’s more likely to be LINE level.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    2-Sony EX-1 HD .
