Activity Forums Blackmagic Design Hot Chroma
  • Hot Chroma
    Posted by Jeff Carson on February 10, 2006 at 4:13 pm
    G5 Quad, 6Gb Ram, OS 10.4.3, FCP 5.04, DSR-40 Component out into BMD Decklink 5.4 drivers…
    Chroma is hot using component inputs. Clips captured this way need about 50% reduction in chroma levels… not good. The images look fine using Firewire input, but we need to use component video inputs and BMD 8Bit or 10 Bit for better keys and color correction… Anyone else getting this symptom?
    Jeff Carson replied 20 years, 6 months ago 3 Members · 6 Replies
  • Jeff Carson
    February 10, 2006 at 4:18 pm
    The Decklink is PCI-e SD version
  • Jeff Carson
    February 10, 2006 at 4:23 pm
    By the way… the Decklink is PCI-e SD version
  • Francois Stark
    February 13, 2006 at 9:45 am
    I have the same problem here on a old Decklink Extreme SD card: The Luma level is way too low, and chroma way too hot.
    I have to use the proc amp – luma slider to the max and chroma slider to the min to get the component in levels better – it’s almost right but not quite there. SDI capture on the same card is perfect. Component out and SDI out is perfect. PAL – not NTSC.
    Regards
    Francois
  • Jeff Carson
    February 13, 2006 at 2:34 pm
    Yep. Same here. Anyone have a solution?
  • Kristian Lam
    February 16, 2006 at 5:29 am
    Hi guys,
    Can you contact us via the support webform available here and we’ll try to sort this out?
    https://blackmagic-design.com/support/contact/
    regards
    Kristian
    Blackmagic Design
  • Jeff Carson
    February 17, 2006 at 11:26 pm
    Thanks Liam… it is on its way…
