Activity Forums Maxon Cinema 4D Hose between 2 objects: point me in the right direction
  • Hose between 2 objects: point me in the right direction
    Posted by Bert Brown on October 1, 2008 at 6:45 pm
    I’ve explored different methods, but I’m curious what the board suggests:
    I’m making an old tyme deep sea diver with an air hose going from his helmet to his boat or a submarine, whatever.
    What’s the best way to keep it so the ends of the hose can be parented to his helmut and the boat, respectively? I dont care if the hose stretches unrealistically.
    And what’d be really hot is if I could give it a sag from gravity, but one step at a time.
    thanks
    Bert Brown replied 17 years, 11 months ago 3 Members · 3 Replies
  • Brian Jones
    October 2, 2008 at 2:14 am
    https://www.black-and-white-to-color.com/ipbsfx/index.php?showtopic=2133
    a couple of the tutes mentioned in the response to this thread could be useful
  • Randy Johnson
    October 2, 2008 at 5:04 am
    Here is another option.It is the second part of the series. You dont need to watch the first but its pretty good for learning the range mapper. If i had to pick just one tutorial as an introduction to xpresso this would be it.
    https://www.c4dcafe.com/ipb/index.php?autocom=downloads&showfile=125
    in short you use an expression to hold the point to a null. And then you control the null with xpresso too. I used this method to swing a light fixture just yesterday.
    /randy
  • Bert Brown
    October 2, 2008 at 2:42 pm
    thanks to both responders. i will check these out.
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
